itchn2go Posted February 9, 2011 Share Posted February 9, 2011 I have a 99RX300 with a check engine light on. Auto Zone read P1131 but does not know what it means. i am unable to locate that code. Does anyone have this information? Ed Quote Link to comment Share on other sites More sharing options...
joe913 Posted February 9, 2011 Share Posted February 9, 2011 This is a list of the codes produced by OBDII All of which will cause the Check engine light to stay on. P0100 MAF Malfunction P0101 MAF Circuit Range/Performance P0110 IAT Circuit Malfunction P0115 ECT Circuit Malfunction P0116 ECT Circuit Range/Performance P0120 TP Position Sensor/Switch ‘‘A’’ Circuit Malfunction P0121 TP Position Sensor/Switch ‘‘A’’ Circuit Range/Performance P0125 Insufficient Coolant Temperature For Closed Loop Fuel Control P0130 HO2S Circuit Malfunction, Bank 1 Sensor 1 P0133 HO2S Circuit Slow Response, Bank 1 Sensor 1 P0135 HO2S Heater Circuit Malfunction, Bank 1 Sensor 1 P0136 HO2S Circuit Malfunction, Bank 1 Sensor 2 P0141 HO2S Heater Circuit Malfunction, Bank 1 Sensor 2 P0150 HO2S Circuit Malfunction, Bank 2 Sensor 1 P0153 HO2S Circuit Slow Response, Bank 2 Sensor 1 P0155 HO2S Heater Circuit Malfunction, Bank 2 Sensor 1 P0156 HO2S Sensor Circuit Malfunction, Bank 2 Sensor 2 P0161 HO2S Heater Circuit Malfunction, Bank 2 Sensor 2 P0170 Fuel Trim Malfunction P0171 System Too Lean (Fuel Trim) P0172 System Too Rich (Fuel Trim) P0174 System Too Lean (A/F Lean Malfunction, Bank 2) P0175 System Too Rich (A/F Rich Malfunction, Bank 2) P0300 Random Misfire Detected P0301 Misfire Detected, Cylinder 1 P0302 Misfire Detected, Cylinder 2 P0303 Misfire Detected, Cylinder 3 P0304 Misfire Detected, Cylinder 4 P0305 Misfire Detected, Cylinder 5 P0306 Misfire Detected, Cylinder 6 P0307 Misfire Detected, Cylinder 7 P0308 Misfire Detected, Cylinder 8 P0325 KS 1 Circuit Malfunction P0330 KS 2 Circuit Malfunction P0335 CKP Sensor ‘‘A’’ Circuit Malfunction P0340 CMP Circuit Malfunction P0385 CKP Sensor ‘‘B’’ Circuit Malfunction P0401 EGR Insufficient Flow P0402 EGR Excessive Flow P0403 EGR Circuit Malfunction P0420 Catalyst System Efficiency Below Threshold Bank 1 P0430 Catalyst System Efficiency Below Threshold Bank 2 P0440 EVAP Emission Control System Malfunction P0441 EVAP Emission Control System Improper Purge Flow P0446 EVAP Emission Control System Vent Control Malfunction P0450 EVAP Emission Control System Pressure Switch Malfunction P0451 EVAP Control System Pressure Sensor Range/Performance P0500 VSS Malfunction P0505 Idle Control System Malfunction P0510 Closed TP Switch Malfunction P0550 Power Steering Pressure Sensor Circuit Malfunction P1100 BARO Sensor Circuit Malfunction P1120 Accelerator Pedal Position Sensor Circuit Malfunction P1121 Accelerator Pedal Position Sensor Range/Performance Problem P1125 Throttle Control Motor Circuit Malfunction P1126 Magnetic Clutch Circuit Malfunction P1127 ECTS Actuator Power Source Circuit Malfunction P1128 Throttle Control Motor Lock Malfunction P1129 Electronic Throttle Control System P1130 Air/Fuel Ratio Sensor Circuit Range/Performance Malfunction (Bank 1 Sensor 1) P1133 Air/Fuel Ratio Sensor Circuit Response Malfunction (Bank 1 Sensor 1) P1135 Air/Fuel Ratio Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) P1150 Air/Fuel Ratio Sensor Circuit Range/Performance Malfunction (Bank 2 Sensor 1) P1153 Air/Fuel Ratio Sensor Circuit Response Malfunction (Bank 2 Sensor 1) P1155 Air/Fuel Ratio Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) P1200 Fuel Pump Relay/ECU Circuit Malfunction P1300 Igniter Circuit Malfunction (Bank 1 Or No. 1) P1305 Igniter Circuit Malfunction, (Bank 2 Or No. 2) P1310 Igniter Circuit Malfunction (No. 3) P1315 Igniter Circuit Malfunction (No. 4) P1320 Igniter Circuit Malfunction (No. 5) P1325 Igniter Circuit Malfunction (No. 6) P1330 Igniter Circuit Malfunction (No. 7) P1335 CKP Sensor Circuit Malfunction During Engine Running P1340 Igniter Circuit Malfunction (No. 8) P1345 VVT Sensor Circuit Malfunction (Bank 1) P1346 VVT Sensor Rang/Performance Problem (Bank 1) P1349 VVT System Malfunction (Bank 1) P1350 VVT Sensor Circuit Malfunction (Bank 2) P1351 VVT Sensor Range/Performance Problem (Bank 2) P1354 VVT System Malfunction (Bank 2) P1400 Sub-TP Sensor Malfunction P1401 Sub-TP Sensor Range/Performance P1410 EGR Valve Position Sensor Circuit Malfunction P1411 EGR Valve Position Sensor Circuit Range/Performance Malfunction P1500 Starter Signal Circuit Malfunction P1520 Stop Lamp Switch Malfunction P1565 Cruise Control Main Switch Circuit Malfunction P1566 Cruise Control Main Switch Circuit Malfunction P1600 ECM BATT Malfunction P1605 Knock Control CPU Malfunction P1633 ECM Malfunction (ETCS Circuit) P1645 Body ECU Malfunction P1656 OCV Circuit Malfunction (Bank 1) P1663 OCV Circuit Malfunction (Bank 2) P1780 PNP Switch Malfunction B2785 Ignition Switch On Malfunction (Immobilizer System) B2786 Ignition Switch Off Malfunction (Immobilizer System) B2785 Ignition Switch On Malfunction (Immobilizer System) B2791 Key Unlock Warning Switch Malfunction (Immobilizer System) B2795 Unmatch Key Code (Immobilizer System) B2796 No Communication In Immobilizer System B2797 Communication Malfunction No. 1 (Immobilizer System) B2798 Communication Malfunction No. 2 (Immobilizer System) Quote Link to comment Share on other sites More sharing options...
joe913 Posted February 9, 2011 Share Posted February 9, 2011 Additionally, the file at the following location will be helpful in tracking your problem: http://www.box.net/shared/o55c5697lt#/shared/o55c5697lt/1/9328827/92955307/1 Quote Link to comment Share on other sites More sharing options...
