CHF Posted January 11, 2011 Share Posted January 11, 2011 Hi, I am hoping this maybe a simple fix. I went to open the fuel filler door and the lever wouldn't work (so I had to use the manual release in the truck). The next day I noticed that my left low-beam light was out. I'm wondering if these maybe related/same fuse or coincidental. Thanks, Chris Quote Link to comment Share on other sites More sharing options...
landar Posted January 11, 2011 Share Posted January 11, 2011 Hi, I am hoping this maybe a simple fix. I went to open the fuel filler door and the lever wouldn't work (so I had to use the manual release in the truck). The next day I noticed that my left low-beam light was out. I'm wondering if these maybe related/same fuse or coincidental. Thanks, Chris While I do not have schematics for the 96 LS, I sincerely doubt that Lexus uses the same fuse for the fuel door and left low-beam. Both being out is just coincidence. I believe that the trunk release also uses the gas filler release fuse, so if the electric trunk release works, your fuse is good. Do you hear any clicks at all when you pull the gas door lever in the cabin? Sometimes the rubber bumper pushing on the door gets rotted/damaged and does not exert outward force to open the lid. Quote Link to comment Share on other sites More sharing options...
CHF Posted January 12, 2011 Author Share Posted January 12, 2011 Thanks - I think you're right as the fuel filler lever(FFL) worked today but the light is still out. I am wondering if maybe the FFL doesn't work if the car is running or something? I'm in Oregon and, as such, only have full-serve so the guy was waiting for me to open it and I was flustered so maybe that was issue? Nonetheless, it works now (it's a bit warmer today if that's relevant) and I purchased a replacement bulb so that is my next task. Thanks again, Chris Hi, I am hoping this maybe a simple fix. I went to open the fuel filler door and the lever wouldn't work (so I had to use the manual release in the truck). The next day I noticed that my left low-beam light was out. I'm wondering if these maybe related/same fuse or coincidental. Thanks, Chris While I do not have schematics for the 96 LS, I sincerely doubt that Lexus uses the same fuse for the fuel door and left low-beam. Both being out is just coincidence. I believe that the trunk release also uses the gas filler release fuse, so if the electric trunk release works, your fuse is good. Do you hear any clicks at all when you pull the gas door lever in the cabin? Sometimes the rubber bumper pushing on the door gets rotted/damaged and does not exert outward force to open the lid. Quote Link to comment Share on other sites More sharing options...
steve79 Posted January 12, 2011 Share Posted January 12, 2011 Hi mine is a 96 model and the FFL will not open while engine is running, the boot sorry trunk will not open either Steve. Quote Link to comment Share on other sites More sharing options...
CHF Posted January 13, 2011 Author Share Posted January 13, 2011 Thanks Steve - I need to try that again as I feel like I tried while the engine was off & on - but that explains that, Cheers Quote Link to comment Share on other sites More sharing options...
landar Posted January 13, 2011 Share Posted January 13, 2011 Just tried my LS430. Both the 'boot' and gas filler door open with the engine running. Quote Link to comment Share on other sites More sharing options...
Mile_High_Flyer Posted January 16, 2011 Share Posted January 16, 2011 Just tried my LS430. Both the 'boot' and gas filler door open with the engine running. Likewise with my 1999 LS400, both work with engine running or not. Cheers, Keith. Quote Link to comment Share on other sites More sharing options...
