1997 Es300 Center Ac Vents Aren't Blowing
bragaman
If you hear the HVAC motor closing or opening a vent, its possible that the motor works, but that the door mechanism has stripped, or the door has broken from its pivot points. Its also possible that you are hearing a vent motor operating, but its not the one for the dash vents, which may not be working. The only way to find out is to remove the knee panel under the glove box, and the glove box, and get access to the blower and vent mechanisms.
