yidaitianjiaous Posted December 21, 2010 Share Posted December 21, 2010 i just niticed this morning that a light L/H overhead the back seat is on. the reading light ok with the switch on/off. also, the light on the bottom of the L/H back door stays on even though door is closed. cant' find a switch for the lights. any Idea welcomed. its' 92 LS400. thx heavry rain in Southern california for days and back ceiling alos soaked. Quote Link to comment Share on other sites More sharing options...
steve2006 Posted December 21, 2010 Share Posted December 21, 2010 Sounds like the door switch,it is mounted under a rubber cover 3" below and opposite the chrome door latch on the rear of the door frame. Pull back the rubber cover which will expose the fastening screws. Make sure the wire doesn't disappear thru the hole if you remove the connection from the switch. If you have a wet roof lining check the moonroof drain holes located at the front corners when the roof is opened. Quote Link to comment Share on other sites More sharing options...
yidaitianjiaous Posted December 21, 2010 Author Share Posted December 21, 2010 lot of thx, i will chk it out... this morning, i had to pull out the wire to the reading light and pull out the bulb on the door...haha... heavy rain these days, i will chaeck the drain hole on the moon roof. thx again. you have a very happy holiday Quote Link to comment Share on other sites More sharing options...
