How do you replace the front left hand turn signal bulb? Any advice would be greatly appreciated! Thanks.
Open the hood and see if you can reach your hand behind the directional bulb. Not sure if you need to remove any parts to gain access to it...
If you can feel the back of it, twist the socket counterclockwise, then pull out.
Click here for a document that will help with any future electrical problems around the body of the car. Good luck.
