95 Es Sunvisor Repair?
nickm11
Hi
I saw the other posts on removing and repairing the driver side sunvisor, but I'm not sure how to remove the plastic cover to get to the screws underneath. Is the cover popoff or slide away from the other part? Is there a push in that hold the cover on?
Thanx,
  • 4 weeks later...
I would think it is a pop off. Did you try?
I finally talked to my repair shop about it and yes it is a pop off. I'm glad I did get an answer, because it's an easy pop off that is a simple pull on the tip, but if you go in to fa with your tool, you will break the cover.
