aussie 1 Posted November 17, 2010 Share Posted November 17, 2010 Hi, just purchased 93 ES300, drove home in typical alberta weather and could not get washer to work, checked fluid OK, any tips? Quote Link to comment Share on other sites More sharing options...
pj8708 Posted November 19, 2010 Share Posted November 19, 2010 Not an expert, but you could start by checking to see if the fluid pump is working. When you pull/press the stalk to activate the washers check to see if there is any sound or noise at either the sprayer nozzle end or the reservoir end. The nozzles may be plugged with gunk and can be cleaned with a fine gauge wire. I have filled the reservoir with very warm water and pumped it through several cycles to clean out the tubing. Search subject on this forum. Maybe an expert will chime in here soon. Paul Quote Link to comment Share on other sites More sharing options...
