Locked Out! Grrr!
TradeMarck
Ok,
I'm a new used Lexus owner and I've some how locked myself out to the car. The remote key was working fine and it can be locked from the outside with the key. I turned off the remote button inside the car and locked the door from the outside. NOW, the door won't unlock with the key nor the remote button. The battery has been changed in the key but since the remote button was turned off, it won't work regardless.
The key will turn left to lock but not right to unlock. I don't have a manual and my local Lexus dealer is too busy to answer my calls. A mechanic friend suggested to lift the door handle half way up and turn to the right...
No luck.
Any help would be much appreciated!!!!!
Sounds like you have an early 90's LS. Try wiggling/jiggling the key in the door lock while turning clockwise. I will bet you can get it to unlock that way. Also try the passenger side as well if you have no luck with the driver's side.
