navyprgirl Posted August 26, 2010 Share Posted August 26, 2010 I just bought my GS 350 and I am frustrated by the voice commands feature. I previously owned an Infiniti G37 and I loved the voice feature because there was a list of commands in the owners manual and I simply memorized the ones I wanted to use frequently and then said a few words while driving to use the features I needed. With the Lexus, it seems I have to take my hands off the wheel all the time to use the touch screen or go through endless voice commands to get what I want. For example-to make a phone call hands free, I press the voice button, say phone, and then the car prompts me to say a command "like dial by number, dial by name, etc, etc. Then after I listen to all the examples, I have to wait for the beep before I can say the command I want even though I am smart enough to remember it and dont need to hear the list every stinking time. Isnt there a way to by pass all those words and just say dial home or something like that? Help! Quote Link to comment Share on other sites More sharing options...
LEXIRX330 Posted August 26, 2010 Share Posted August 26, 2010 On my GX you can change it so you hold the speak button it beeps and you say what you want dial by name or temp 74, etc...I assume it is the same so here you go! GO to Settings. Scroll down to Voice Recognition and select OFF. That should make it so you don't have to listen to all of the commands each time. Quote Link to comment Share on other sites More sharing options...
navyprgirl Posted August 27, 2010 Author Share Posted August 27, 2010 On my GX you can change it so you hold the speak button it beeps and you say what you want dial by name or temp 74, etc...I assume it is the same so here you go! GO to Settings. Scroll down to Voice Recognition and select OFF. That should make it so you don't have to listen to all of the commands each time. Thank you very much-it worked. Appreciate the tip! Quote Link to comment Share on other sites More sharing options...
LEXIRX330 Posted August 27, 2010 Share Posted August 27, 2010 Thank you very much-it worked. Appreciate the tip! No problem... I started to go crazy too... Phone...Dial By Name...Wifey...Mobile...Dial...ERR...by that time I could of pulled over and dialed the number. Quote Link to comment Share on other sites More sharing options...
