05Ls430 Power Outlets Not Working
jasperaxle
My cellphone charger suddenly stopped working in any outlet I tried it in so I tried in my wifes car to make sure it wasnt the charger itself. I also tried the cigarette lighter and that didnt work either. As I said I check all fuses per the ownwers manual but they were all ok.
Next, I would use a voltmeter to measure the fuse terminals of the outlet fuses. Connecting the - probe to ground(chassis) and the + probe to each side of the fuse socket(remove the fuse), what do you get for readings? For grins and giggles, you might also put the meter on the ohm scale and measure the resistance of the fuse itself. Let us know what you get for readings.
