drgkjl Posted August 20, 2010 Posted August 20, 2010 2006 400h. the abs light came on...is there a way to get diagnostic info about the defective component without specialized tools (that dealers have)? e.g., in acura one can get info by shorting two pins in a service connector; the abs light flashes and provides a 2-digit code. thanks
lemon Posted August 20, 2010 Posted August 20, 2010 2006 400h. the abs light came on...is there a way to get diagnostic info about the defective component without specialized tools (that dealers have)? e.g., in acura one can get info by shorting two pins in a service connector; the abs light flashes and provides a 2-digit code. thanks Just curious, have you had a brake job done recently where you or the mechanic tried to bleed the brakes? You can't bleed the brakes on the hybrid the same way you can with a conventional vehicle.
drgkjl Posted August 21, 2010 Author Posted August 21, 2010 2006 400h. the abs light came on...is there a way to get diagnostic info about the defective component without specialized tools (that dealers have)? e.g., in acura one can get info by shorting two pins in a service connector; the abs light flashes and provides a 2-digit code. thanks no, no work done on brakes. the car has only 36K miles. the strange thing is that the light came on when the car was stand-still as was stopped at a traffic light. Just curious, have you had a brake job done recently where you or the mechanic tried to bleed the brakes? You can't bleed the brakes on the hybrid the same way you can with a conventional vehicle.
