Replace Rear Break Pads
How do I remove the rear break pads on the 2003 ES300 since it has only 1 bold at the back bottom of the caliper. The front have 2 bolts which is easy. the rear is difference. How do I remove the rear caliper while no top bolt to remove? I am kind confuse. Can any one help please?
You're going to kick yourself when you find out how easy it is! Quite simple. Remove that one caliper bolt and ..... wait for it..... rotate the entire caliper upwards until it clears the rotor, and pull the entire caliper towards you. The caliper will come off with the top slide pin still attached to it. Its a strange setup to be sure, but seems to work well for Toyota. Good Luck!
