A/c Leak Onto Passenger Floor
Can't wait to hear more responses on this one! I have a 07 ES350 and recently discovered puddling of water under ALL the floor mats. The rubber backed mats prevented me from noticing the problem for some time. It's starting to smell! The dealer thought it was a clogged AC line; taking the car in on Tuesday.
Did you get an answer? I have the same problem on my SC400 passenger floor side...
it leaks because the drain tube that normally goes to the engine compartment to drain the condensation, has been plugged or crimped....look below the abs module for a rubber tube coming from the firewall.
