cr_driver Posted July 29, 2010 Share Posted July 29, 2010 Hello guys! I need to replace my tires ASAP, car is the 06 GS300 AWD. Went to tirerack.com , when I chose the tires, it gave me this warning: Important Notes: "OE Dunlop SP5000M DSST CTT has a very large OD (27.1) appearance compared to 225/50-17 tires (25.9). The OE Dunlop tire uses CTT technology, that conforms the tread to 25.9 under static load. Replacing Dunlop with other 225/50-17 tires will look shorter, but are proper OD for vehicle electronics. Using larger OD tires to match Dunlop cosmetically will have adverse effects on vehicle electronics" What does that mean? I am not buying the OE Dunlops. I am buying the same size thou, 225/50 R17. Can I buy whatever brand with no problem? WHy the warning then? THANKS. Quote Link to comment Share on other sites More sharing options...
cr_driver Posted July 29, 2010 Author Share Posted July 29, 2010 Also, looking at the manual "When replacing the tires and wheels, be sure to install tire pressure warning valves and transmitters. ID codes on the tire pressure warning valves and transmitters are registered on the tire pressure warning ECU. When replacing a tire pressure warning valve and transmitter, it is necessary to register the ID code of tire pressure warning valve and transmitter. Have the ID code registered by your Lexus dealer." Where do I get the pressure warning valves and trasmitters? How do I register that ID code? I am not talking it to a dealer I have all these questions cause its my first time with a TPMS, so I would like to know what to do, what`s the procedure. If I put 225/55`s, will they rub the fenders? Quote Link to comment Share on other sites More sharing options...
