NV008-06: Rattle Noise from Headliner Area:
States:
Some customers may experience a buzz or slight rattle noise from the rear portion of the headliner when the vehicle hits small sharp bumps. It has been determined that the source of such a rattle may be the Tire Pressure Warning System (TPWS) antenna located above the headliner between the rear of the sliding roof opening and the top of
the back glass.
I notice that my ES 2008 is having this problem, It happen with i slam the doors, hit bumps, it is well located on that area since by tapping on it, the buzzing sound occurs. I've called Lexus and my model year is not aimed. Has anyone did the repair on that area and if it solved the problem.
thank you.
