Anyone know how to rewire the 3rd brake light on the spoiler to the back window shelf where the back speakers are. Is there another brake light wire that runs behind the back seat.
  • 1 month later...
Not sure if all the cars were fitted with this but if you remove your right cover in the trunk you may find the wiring for the 3rd brake light. If not then you will have to go directly from the third brake light housing to make your connections. The good news is that the housing can be removed without taking the whole shelf off. The bad is that you will have to route your wires to it. It will be easier if you remove the covers from your trunk.
