lexus1995ls400owner Posted June 1, 2010 Share Posted June 1, 2010 Can someone recommend a mechanic/shop in Orlando FL that has Lexus/Toyota experience. I need to replace the power steering pump on my 95 LS400 (The pump has very little power assist at idle). The solenoid filter has been cleaned (preventive maintenance), the ACV valve under the power steering pump has been replaced (due to a leak), and the fluid flushed. I think the next thing is the PS pump. Thanks. Quote Link to comment Share on other sites More sharing options...
landar Posted June 4, 2010 Share Posted June 4, 2010 Can someone recommend a mechanic/shop in Orlando FL that has Lexus/Toyota experience. I need to replace the power steering pump on my 95 LS400 (The pump has very little power assist at idle). The solenoid filter has been cleaned (preventive maintenance), the ACV valve under the power steering pump has been replaced (due to a leak), and the fluid flushed. I think the next thing is the PS pump. Thanks. Have you tried -> http://www.cartalk.com/content/mechx/find.html Quote Link to comment Share on other sites More sharing options...
