96 Es300 Atf Level Check
What is the proper way to check the AFT fluid level? Is it more accurate to check it when its hot or cold?
Err depends if the dipstick for the fluid has both the hot/cold markings (on each flat side) offhand i cant remember for the '96 sorry.
just pull it and look. if its cold then cold, hot then hot ;)
regardless its pretty much the same thing. ive checked it both ways hot you just leave the car running in park while checking it after driving for a bit.
