ldm616 Posted May 17, 2010 Posted May 17, 2010 My dealer tells me my 2004 GX470 needs a major service every 30k miles. That seems reasonable. But they also say it needs to come in every 5k miles between major services? Is that really true? I have about 110k miles on the vehicle. Thanks in advance for any replies.
LEXIRX330 Posted May 17, 2010 Posted May 17, 2010 My dealer tells me my 2004 GX470 needs a major service every 30k miles. That seems reasonable. But they also say it needs to come in every 5k miles between major services? Is that really true? I have about 110k miles on the vehicle. Thanks in advance for any replies. They are saying for routine maintenance every 5k...oil change, tire rotation...etc. You can use an independent shop.
valgal Posted September 16, 2010 Posted September 16, 2010 My dealer tells me my 2004 GX470 needs a major service every 30k miles. That seems reasonable. But they also say it needs to come in every 5k miles between major services? Is that really true? I have about 110k miles on the vehicle. Thanks in advance for any replies. They are saying for routine maintenance every 5k...oil change, tire rotation...etc. You can use an independent shop. I just hit 30K on a preowned 05 and the dealer recommended a 30k service totaling $500. I passed and figured I do a little research first - do anyone know what is truly necessary? Thanks!
LEXIRX330 Posted September 17, 2010 Posted September 17, 2010 My dealer tells me my 2004 GX470 needs a major service every 30k miles. That seems reasonable. But they also say it needs to come in every 5k miles between major services? Is that really true? I have about 110k miles on the vehicle. Thanks in advance for any replies. They are saying for routine maintenance every 5k...oil change, tire rotation...etc. You can use an independent shop. I just hit 30K on a preowned 05 and the dealer recommended a 30k service totaling $500. I passed and figured I do a little research first - do anyone know what is truly necessary? Thanks! Look in the service book in your car, or online it will tell you. Most of it I think is inspections. I think many times you are safe to have the oil changed and fluids topped off. Take a look at Lexus.com and register your car you should be able to get the service intervals.
