Hi, I purchased a nice RX 400h three days ago and am still getting used to it. On the GPS, I set the address for my home and went through the manual to set it up as a memory and registering it. It shows that I have 105/106 registered memory spots available so it looks like I successfully registered it. When I use the voice command and say "home", it says "home is not registered". I don't know how to get this to work. Can I get some help on what I might be doing wrong? Thanks.
  • 3 weeks later...
If you press the "DEST" button on the console, a screen will pop up with a little home icon at the bottom left. If you press it, does it work? Does it take you to your home?
If so then you've definitely registered it as your "home". If not, you'll need to play around with it more.
