dblack Posted April 3, 2010 Share Posted April 3, 2010 OK, outside door handle doesn't work, but inside door handle works. Ive read a lot on this (mostly from this forum) and i initially determined that it was likely the clip, but i wanted to take a look to be sure. so i tore the door apart and the bar that goes from the handle to the mech was broken and laying at the bottom of the door. to make things worse i called the Lexus dealership and asked about prices for parts. they claimed that i couldn't buy the clip individually, and that the entire assembly was going to put me back over $400(ouch). so i checked junk yards (i live in Hawaii, so junk yards are limited), what i found was ES and LS Lexus models littering junkyards but NO SC models at all. So now Ive got 2 questions first question can anybody give me part numbers? second question, can these parts be sourced from a different car? Thanks in advance. BTW, maybe I'm weird, but it was rather easy for me to access the mech for the door handle, i don't see how so many people had trouble. Quote Link to comment Share on other sites More sharing options...
grnsc40095 Posted April 4, 2010 Share Posted April 4, 2010 dblack, The links below will help with your problem, Good Luck! Post 85 is one possible fix http://www.clublexus.com/forums/sc-400-300/200819-so-your-door-handle-doesnt-work-diy-w-pics-6.html Another fix Post 145 http://www.clublexus.com/forums/sc-400-300/200819-so-your-door-handle-doesnt-work-diy-w-pics-10.html Post 55 This Sc vendor can get you the used part use his AOL IM to contact http://www.clublexus.com/forums/sc-400-300/200819-so-your-door-handle-doesnt-work-diy-w-pics-4.html Quote Link to comment Share on other sites More sharing options...
dblack Posted April 8, 2010 Author Share Posted April 8, 2010 Thanks for the info. I attempted to contact this guy over AIM, no luck, hes online sometimes, but he never replies. Im going to send him a message on here and see if he responds here. Quote Link to comment Share on other sites More sharing options...
