Hi Everyone,
I need some advice again about my '04 GX470.
1. When I shift from reverse to park, after 1 or 2 seconds, I hear a click from the transmission, under the shifter. It's not loud but you can hear it.
Is that normal?
2. And also my side mirrors don't go down anymore when I shift to reverse to back up. Is there a switch for that?
Thanks in advance!!!
Dustin
Hi Everyone,
Is that normal?
Dustin
Not sure if the GX works the same as my LX, but here it is.
1) the click sound might be the shift lock? Like a lock that wouldn't allow you to shift to reverse if you car's in forward motion?
Try to shift it into park (P), step on the brakes and see if its the same click sound.
2) the square that controls you side mirrors, in the middle is a switch where you flick it left or right or middle, keep that switch to the right side, see if it works!
Golfson,
I was having same problem with mirrors not tilting down in reverse; your tip worked. Had to register and say 'thanks'!
