How To Remove Coil Packs For Spark Plugs 99 Gs 300?
Can someone tell me how to remov the coil packs to replace spark plugs on 99 GS 300. I have read the guides but none say exactly how to remove them. Thank You
After you have the top of the engine disassembled with the engine dress cover removed simply disconnect the three coil power wire connectors. Then loosen the 5 retaining bolts for the coil packs and lift them straight up and out. Be careful with the high-tension wires as they may be a little dried out and possibly brittle. Take note of how they're routed before disconnecting everything so you can get it right on reassembly.
