Doninator007 Posted February 25, 2010 Share Posted February 25, 2010 Both my rear tail lights and the license plate light are not functioning. When I replace the 7.5 Fuse in the #12 slot on the inside kick panel of the car, the fuse burns out every time I turn on the headlights. I have checked all the bulbs of course and everything is in order. Any assistance would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Gil In Mechanicsville Posted February 25, 2010 Share Posted February 25, 2010 Both my rear tail lights and the license plate light are not functioning. When I replace the 7.5 Fuse in the #12 slot on the inside kick panel of the car, the fuse burns out every time I turn on the headlights. I have checked all the bulbs of course and everything is in order. Any assistance would be greatly appreciated. You are going to have to trace down the dead short you have somewhere in the wiring assembly, Likely you have worn a bare spot in the hot lead or if you have added anything to the car you may have pierced the wire. The wiring harness runs under the rear seat. It is an easy fix but very time consuming to find. Quote Link to comment Share on other sites More sharing options...
