2006 Gx Check Engine Light On,vsc Trac And Vsc Off
mytwosons
Nothing serious,
DTC No. DTC Detecting Condition Trouble Area
P0442
P0456
After cold engine start.
After VSV for EVAP operation, the VSV for EVAP is turned off
sealing the vacuum in the system and the ECM begins to monitor
the pressure increase.
Some increase is normal. A very rapid, sharp increase in pressure
indicates a leak in the EVAP system and sets the DTC
P0442.
This monitoring method is also able to distinguish what is
called the small leak detection.(DTC P0456)
A pressure rise just above normal indicates a very small hole.
Fuel tank cap incorrectly installed
Fuel tank cap cracked or damaged
Hose or tube cracked, hole, damaged or loose seal ((3) or (9)
in Fig. 1)
Vacuum hose cracked, holed, blocked, damaged or disconnected
((1), (2), (4), (5), (6), (7), (8), (10)and (11) in Fig. 1)
Fuel tank cracked, holed or damaged
Charcoal canister cracked, holed or damaged
Open or short in vapor pressure sensor circuit
VSV for CCV
VSV for EVAP
VSV for pressure switching valve
Vapor pressure sensor
Fuel tank over fill check valve cracked or damaged.
What you should do is
Check your Gas Tank Cap,probably it would be loose while you did last re-fueling.
Next go below your car, there is hose from the Fuel Tank which connects the VSV canister, check out the hose clamp and have them re-tightened.
Now Disconnect the battery terminal (-) and EFI fuse, to erase the DTC code in the ECM memory. And have them reconnected.
That it you are good to go.
Thanks! I will keep you updated.
Nothing serious,
P0442
P0456
P0442.
in Fig. 1)
VSV for CCV
VSV for EVAP
I followed your instruction tightened gas cap and the hose clamp from the fuel tank that connects to the charcoal canister and it works so far so good after a road test.Thank you very much!
Nothing serious,
P0442
P0456
P0442.
in Fig. 1)
VSV for CCV
VSV for EVAP
