maxSteel Posted January 29, 2010 Share Posted January 29, 2010 Hi, does anyone have a repair guide for replacing the driver side rear half-shaft on a 1999 RX300 AWD? Thanks Quote Link to comment Share on other sites More sharing options...
joe913 Posted January 30, 2010 Share Posted January 30, 2010 Hi, does anyone have a repair guide for replacing the driver side rear half-shaft on a 1999 RX300 AWD?Thanks Maybe the attached document will help. Good luck! Automatic_Transsxle__AX__file.pdf Quote Link to comment Share on other sites More sharing options...
joe913 Posted January 30, 2010 Share Posted January 30, 2010 Hi, does anyone have a repair guide for replacing the driver side rear half-shaft on a 1999 RX300 AWD?Thanks Maybe the attached document will help. Good luck! This document may also help. Good Luck! Suspension_and_Axle__SA__file.pdf Quote Link to comment Share on other sites More sharing options...
maxSteel Posted January 31, 2010 Author Share Posted January 31, 2010 Hi, does anyone have a repair guide for replacing the driver side rear half-shaft on a 1999 RX300 AWD?Thanks Maybe the attached document will help. Good luck! This document may also help. Good Luck! Wow those docs are really great. Thanks very much Joe. Quote Link to comment Share on other sites More sharing options...
joe913 Posted February 1, 2010 Share Posted February 1, 2010 Hi, does anyone have a repair guide for replacing the driver side rear half-shaft on a 1999 RX300 AWD?Thanks Maybe the attached document will help. Good luck! This document may also help. Good Luck! Wow those docs are really great. Thanks very much Joe. You're welcome! The documents were passed on to me by another member--keep the sharing going. Quote Link to comment Share on other sites More sharing options...
