93 Gs300 Engine Swap 911 Help!
Hi Guys,
I swapped out my GE engine with a new one. 94K Miles. I replaced the following on the new engine.
valve Cover Gasket
Oil Dipstick gasket
Cam Seals
Rear main seal
Disturbutor oil seal
Power steering gasket
fuel line gaskets
Timing Belt
Water pump
Engine mounts
Tranny mounts
vacuume hoses
I hooked everything back up and the starter will not turn over. I tested the following.
Battery Cable to the Starter 12.67 Volts
Starter connector 6.4 volts
I have applied direct 12volts to the starter connector and the starter turned over.
What could possibly my issue and why am I only getting 6.4 volts at the starter connector?
thanks for the help guys..
Hi Guys,
valve Cover Gasket
Oil Dipstick gasket
Cam Seals
Rear main seal
fuel line gaskets
Timing Belt
Water pump
Engine mounts
Tranny mounts
vacuume hoses
Anyone ???
