ravig292 Posted January 24, 2010 Share Posted January 24, 2010 i have a 2000 ls400 my fog light bulbs stopped working i checked them in another car and they work but i dont know what the problem is. i looked for the fuse but could not find it does anyone know where the fuse is located? or if its not the fuse is it the wires that shorted? Quote Link to comment Share on other sites More sharing options...
curiousB Posted January 24, 2010 Share Posted January 24, 2010 i have a 2000 ls400my fog light bulbs stopped working i checked them in another car and they work but i dont know what the problem is. i looked for the fuse but could not find it does anyone know where the fuse is located? or if its not the fuse is it the wires that shorted? 92% its the fuse 4% its a bad switch 3.9% it could be corroded bulb socket 0.1% its a shorted wire Quote Link to comment Share on other sites More sharing options...
ravig292 Posted January 24, 2010 Author Share Posted January 24, 2010 i dont know where the fuse for it is located i looked at the box but could not find it does anyone know where it is? Quote Link to comment Share on other sites More sharing options...
RDM Posted January 24, 2010 Share Posted January 24, 2010 Owners manual will tell you. There's fuseboxes inside and under the hood. Quote Link to comment Share on other sites More sharing options...
ravig292 Posted January 28, 2010 Author Share Posted January 28, 2010 its not the relay because i hear the relay click when i switch it on. how do i tell if the wires are shorted? if they are would i have to change the wires all the way from the relay? Quote Link to comment Share on other sites More sharing options...
ravig292 Posted January 28, 2010 Author Share Posted January 28, 2010 anyone anyone? Quote Link to comment Share on other sites More sharing options...
Flighing SC Posted February 6, 2010 Share Posted February 6, 2010 should be under the dash on the drivers side. Had to replace my fuse too anyone anyone? Quote Link to comment Share on other sites More sharing options...
xxiiac Posted February 7, 2010 Share Posted February 7, 2010 Under the steering colume is the cover. It has three screws that you need to take out. They are hard to see, you need to look from the floor up to under the steering column area. Take those out and the plastic cover drops down. The fuse box is up on the left hand side. I think the fuse you are looking for is #2 (should be in your owners manual if you have it). I think it is the middle one on the bottom, I believe it is a 15 fuse. Hope this helps. Quote Link to comment Share on other sites More sharing options...
