Innara Posted January 12, 2010 Share Posted January 12, 2010 I own a 06 400h and absolutely love it. I recently had the regular battery replaced (not the hybrid battery). After replacing the battery my BT got flaky. At one point the car wouldn't connect to my phone and wouldn't pare with six other phones that I tried including blackberry's, iphones, and flip phones. For the record, the dealership also couldn't pare a number of different phones that they tried. The dealership was able to finally get it working however I'm not sure I fully understand the result. The dealership told me that the BT problem was a problem with my phone (Blackberry Curve) and that my phone was causing other phones to fail when paring with the car. Has anyone else experienced such a weird issue? Quote Link to comment Share on other sites More sharing options...
lemon Posted January 12, 2010 Share Posted January 12, 2010 No idea about the bluetooth issue, however, make sure the ISC learning procedure is done after replacing the auxilliary battery. See the TSB's stickied at the top of this forum. You can ask the dealer to do it (if they replaced the battery, hopefully it was done) or you can attempt to do it yourself (it's relatively easy - do a search here for ISC learning). Quote Link to comment Share on other sites More sharing options...
Innara Posted January 13, 2010 Author Share Posted January 13, 2010 No idea about the bluetooth issue, however, make sure the ISC learning procedure is done after replacing the auxilliary battery. See the TSB's stickied at the top of this forum. You can ask the dealer to do it (if they replaced the battery, hopefully it was done) or you can attempt to do it yourself (it's relatively easy - do a search here for ISC learning). Thanks for the reply. I will check with the dealer to see if they performed the ISC learning procedure. If not I will follow the steps on the site. Quote Link to comment Share on other sites More sharing options...
