yank30265 Posted January 12, 2010 Posted January 12, 2010 I put power steering fluid in my 90 ls400; it got real cold out and the pump was making horrible noises; after about 2 days i checked the forum and found out why; I sucked out the old fluid which looked like coffee with heavy cream in it and I ran castrol import tranny fluid in it(same as dexron 2) Turned the wheel many times and sucked out the fluid; did this with a whole quart then refilled with clean fluid; everything seems to be ok except at slow speeds the pwr steering seems to be stiff(been like this since i got the car) is there an inline filter before the pump? And ifso where? Thanks
AzHotLS Posted January 12, 2010 Posted January 12, 2010 The rack solenoid screen could be gunked up, remove and clean it with a toothbrush or similar: http://www.clublexus.com/forums/ls400/3438...system-diy.html
