Juliet_Hotel Posted December 27, 2009 Share Posted December 27, 2009 Hey All, I have a 1993 ES300. It has roughly 220k miles on it. Very nice car to say the least. I've been experiencing problems with the engine with it not firing off. Once I put the key in the ignition, I try to crank it but it sounds like belts running together and doens't start. The pistons move, but there isn't a sufficent spark to ignite the cylinders. What should I do? Engine: 6 cyl. 3VZ-FE Trans: 5 Speed Manual Best Regards, Jake Quote Link to comment Share on other sites More sharing options...
stcist2 Posted December 27, 2009 Share Posted December 27, 2009 check the timing belt. Quote Link to comment Share on other sites More sharing options...
sk1951 Posted December 27, 2009 Share Posted December 27, 2009 Hey All,I have a 1993 ES300. It has roughly 220k miles on it. Very nice car to say the least. I've been experiencing problems with the engine with it not firing off. Once I put the key in the ignition, I try to crank it but it sounds like belts running together and doens't start. The pistons move, but there isn't a sufficent spark to ignite the cylinders. What should I do? Engine: 6 cyl. 3VZ-FE Trans: 5 Speed Manual Best Regards, Jake Jake or Juliet: Sounds like you know the problem. Not enough juice to start the engine. If you have a slow cranking situation you might start with a new battery. Quote Link to comment Share on other sites More sharing options...
eatingupblacktop Posted December 27, 2009 Share Posted December 27, 2009 Hey All,I have a 1993 ES300. It has roughly 220k miles on it. Very nice car to say the least. I've been experiencing problems with the engine with it not firing off. Once I put the key in the ignition, I try to crank it but it sounds like belts running together and doens't start. The pistons move, but there isn't a sufficent spark to ignite the cylinders. What should I do? Engine: 6 cyl. 3VZ-FE Trans: 5 Speed Manual Best Regards, Jake Not sure what "like belts running together" means but if you're cranking slowly as 1951 describes, then try starting with another fully charged batt that's known to be good. If it starts, then you'll have to check the charging system to determine the prob. Quote Link to comment Share on other sites More sharing options...
Juliet_Hotel Posted December 29, 2009 Author Share Posted December 29, 2009 Thanks for the Responses! "...you might have to start with a new battery" The battery we put into it was recharged. "...check the timing belt" I'll do it. Hopefully, I'll get it working again. Best Regards, Jake Quote Link to comment Share on other sites More sharing options...
