suraja12 Posted December 7, 2009 Posted December 7, 2009 i got my new 2010 es350 in oct, 2010 - changed the clock to reflect the end of day light savings time in nov when we put an address into the navigation - it gives an approx arrival time - the time on my es350 still shows up as daylight savings time - that is it shows one hour ahead of actual time of arrival - took it to the dealer - who did not know how to set it - informed will investigate and revert back called up lexus - they informed that i should contact the dealer any one has a similar problem or know how to set the clock in the navigation system many thanks
peteanello Posted December 7, 2009 Posted December 7, 2009 i got my new 2010 es350 in oct, 2010 - changed the clock to reflect the end of day light savings time in nov when we put an address into the navigation - it gives an approx arrival time - the time on my es350 still shows up as daylight savings time - that is it shows one hour ahead of actual time of arrival - took it to the dealer - who did not know how to set it - informed will investigate and revert back called up lexus - they informed that i should contact the dealer any one has a similar problem or know how to set the clock in the navigation system many thanks My '09 ES does the same thing. I fooled around with the settings for some time, and no luck. So, now I touch the clock (arrival time) and it converts to hours and minutes remaining. I've had other vehicles with Nav and they all set the clock (dashboard display) automatically. This is the first one that does not.
JEB01 Posted December 14, 2009 Posted December 14, 2009 i got my new 2010 es350 in oct, 2010 - changed the clock to reflect the end of day light savings time in nov when we put an address into the navigation - it gives an approx arrival time - the time on my es350 still shows up as daylight savings time - that is it shows one hour ahead of actual time of arrival - took it to the dealer - who did not know how to set it - informed will investigate and revert back called up lexus - they informed that i should contact the dealer any one has a similar problem or know how to set the clock in the navigation system many thanks It's actually a different clock. Go to Setup and you can change it.
suraja12 Posted December 14, 2009 Author Posted December 14, 2009 i got my new 2010 es350 in oct, 2010 - changed the clock to reflect the end of day light savings time in nov when we put an address into the navigation - it gives an approx arrival time - the time on my es350 still shows up as daylight savings time - that is it shows one hour ahead of actual time of arrival - took it to the dealer - who did not know how to set it - informed will investigate and revert back called up lexus - they informed that i should contact the dealer any one has a similar problem or know how to set the clock in the navigation system many thanks It's actually a different clock. Go to Setup and you can change it. thanks - got it done - i had turned on the daylight savings time - hence the problem
