Nav Brightness And Contrast
PJA41
I would wonder if a reset of the Nav system wouldn't solve the problem and set every parameter back to its default state. It may well be that the software has got itself in a lockup situation on the screen parameters. You'll need to talk to a Lexus technician or check your manual to see if it provides the reset info procedures.
If that doesn't solve the problem you could have a bad screen which would need to be replaced, and it won't be cheap for sure.
Good Luck!
The Brightness and Contrast of the GPS display on my ES330 that changes with daylight or darkness stopped working. It is in night mode continuously. Any thoughts?
could be that envelope sittng on your dash? covering the daylight/night sensor?maybe.
