Replacing Dash Bulbs
calbsc400
I got a email from a member who was asking how to gain access to the dash buttons so they could change out some bulbs. So here's a series of pictures to show how to gain access.
Remove ashtray to gain access to two screw underneath. Ashtray just pulls out with a little effort. Do not use the lid as a handle
Remove this little button thing with a screwdriver. This allows you to press down inside and move the shifter knob to the nuetral position with the engine off
Push the cover down on the shifter knob. This exposes two screws that you remove to take the shifter handle off.
The black cover is also snaped in carefully remove and there are two screws underneath it. After you disconnect the electrical, remove the panel and the two screws undernearth carefully pull the rest of the dash cover off. At that point you will have access to everything underneath it.
I didn't remove everything because I was just trying to get the posted ASAP. If I try to make it perfect it wouldn't get done.
