micropterus Posted November 27, 2009 Posted November 27, 2009 .... The radio on my sister in law's GS300 won't power up. I checked the fuses listed in the owners manual, number 11 and number 40 (Radio #1 and Radio #2) and they are ok. Anyone ever encounter this type of problem? Any ideas appreciated. Dan Curtis.
kident Posted May 24, 2010 Posted May 24, 2010 .... The radio on my sister in law's GS300 won't power up. I checked the fuses listed in the owners manual, number 11 and number 40 (Radio #1 and Radio #2) and they are ok. Anyone ever encounter this type of problem? Any ideas appreciated. Dan Curtis. I have the same problem. My radio was playing just fine but I cut the car off after lunch and when I came back, it was off and has no power.Did you ever figure out a fix for this? Was your old radio ever tested? Did you try any aftermarket products?
GuyTelefunken Posted May 25, 2010 Posted May 25, 2010 Also check the DOME 10A fuse in the passenger-side footwell.
RTHayes63 Posted July 23, 2013 Posted July 23, 2013 Anybody get a fix for this? Mine is doing it too.
pj8708 Posted July 25, 2013 Posted July 25, 2013 Anybody get a fix for this? Mine is doing it too. Hi Todd and welcome to the Lexus Owners Club. My first guess is still a fuse check. I don't know the layout for a 2001 GS, but I did find a complete layout of all fused circuits for a 2010. I realize there are probably some diffrances, but the one thing I did discover is that in th 2010 there are 3 fuse links for the audio, not just 2. All of those fuses are located in the fuse box under the hood, top left hand side. There are 2 "audio system" 30 amp fuses for the amplifier. There is 1 "audio system" radio fuse. These appear to be the only fuses designated for the head unit/radio. It is always best to pull the fuse out to make sure it is blown or not. Paul
seanbeck Posted September 29, 2014 Posted September 29, 2014 I have the exact same problem with the radio's sudden death. It is a original oem radio without a navigation. The 2001 fuse layout is different from that of 2010 model. The 2001 model has only 2 fuses related to RADIO (#11 & #40) as micropterus indicated. And I checked both fuses and they are OK. Has anyone find out a resolution or fix? Any help would be appreciated.
Moto_01 Posted January 1, 2017 Posted January 1, 2017 I know this is an old post but has anyone found a solution to this problem. My Lexus GS300 2001 radio has no power but the GPS seems to work. Thanks.
dearsx Posted November 3, 2022 Posted November 3, 2022 Dome 10A switch under passenger foot well was blown in mine. Replaced and radio now working 1
