Blk Blood Posted October 15, 2009 Share Posted October 15, 2009 Hello again... Simple question here, ive noticed the the right side of my trunk is leaking.. and causing quite a smell inside it. I remember seeing a post on something similar but cant find it, ANyone know of an easy quik fix for this. Or should i replace the trunk?? lol im in no rush tho, im storing my car for the winter in a few weeks and wld probably get this done next summer. ALong with a whole bunch of other treats! Thanks for anything! Quote Link to comment Share on other sites More sharing options...
CUMan Posted October 16, 2009 Share Posted October 16, 2009 Could be a blocked sunroof drain tube. There are two small holes at the rear corners of the sunroof. Tubes are connected to these drains and carry water from the sunroof assembly and out of the car at the bottom. If one of these tubes gets blocked, the water can get into the trunk. I am not sure where these tubes are located in the trunk, but you should be able to see them by removing the trunk liner. Quote Link to comment Share on other sites More sharing options...
