gunguns Posted September 28, 2009 Share Posted September 28, 2009 About a month ago I became proud owner of a 1998 es300 (105k mikes) from an original owner with all maintenance done at Lexus. On the first day of ownership the driver's side window controller cable broke. I discovered this great forum and following instructions, replaced the controller and put the door all back together. Through trial and error I adjusted the window so that most wind noise was eliminated. I used the paseenger side to determine the correct alignment of the window againt the rubber seal. I still hear some slight buffeting (?) wind noise when driving the car but don't know if this is as good as it gets. I have searched for a way to determine the correct alignment of the window but have not found anything. Any advice? Quote Link to comment Share on other sites More sharing options...
kashi125 Posted September 30, 2009 Share Posted September 30, 2009 Some wind noise is common in these cars. Had it in both my 97 and 99 ES. Quote Link to comment Share on other sites More sharing options...
Nacmias Posted September 30, 2009 Share Posted September 30, 2009 My 00 has very slight wind noise from the drivers side window. I just turn up the radio a little bit and that eliminates everything. Quote Link to comment Share on other sites More sharing options...
Fara Posted October 8, 2009 Share Posted October 8, 2009 I also have wind noise in my 96 e300... Quote Link to comment Share on other sites More sharing options...
