lookingatx Posted September 17, 2009 Share Posted September 17, 2009 Hello, I have a 2001 Lexus ES300 and I have the error codes P1135 and P1155. Since I have 117K on my car, I was going to go ahead and change both Bank 1 Sensor 1 and Bank 2 Sensor 1. The trouble I am having is getting the part numbers for those two sensors so that I can get them off Ebay (as opposed to paying $$$ to the dealer). I did a comprehensive search on Ebay and it seems they either have sensors for 1999 - 2000 ES300 or 2002 and up ES300. Is 2001 ES300 a completely different sensor all together? I pulled the following parts from toyodiy.com MCV20 (2001 ES300 North America) 89467-41020 Rear 89467-41021 Rear 89467-41030 Rear 89467-41040 Front 89467-48010 Front 89467-48011 Front I am confused because the website has three different part numbers for each of the sensors. Can someone please help in choosing which is the correct part number (or are they all same parts with different numbers). Also, If anyone has had success with using DENSO, canyou please give me the part number for those? Thanks a lot!! Quote Link to comment Share on other sites More sharing options...
2JZTWIN TURBO Posted September 17, 2009 Share Posted September 17, 2009 Hello,I have a 2001 Lexus ES300 and I have the error codes P1135 and P1155. Since I have 117K on my car, I was going to go ahead and change both Bank 1 Sensor 1 and Bank 2 Sensor 1. The trouble I am having is getting the part numbers for those two sensors so that I can get them off Ebay (as opposed to paying $$$ to the dealer). I did a comprehensive search on Ebay and it seems they either have sensors for 1999 - 2000 ES300 or 2002 and up ES300. Is 2001 ES300 a completely different sensor all together? I pulled the following parts from toyodiy.com MCV20 (2001 ES300 North America) 89467-41020 Rear 89467-41021 Rear 89467-41030 Rear 89467-41040 Front 89467-48010 Front 89467-48011 Front I am confused because the website has three different part numbers for each of the sensors. Can someone please help in choosing which is the correct part number (or are they all same parts with different numbers). Also, If anyone has had success with using DENSO, canyou please give me the part number for those? Thanks a lot!! If you give me your VIN I can tell you what ones you need. -Terry Quote Link to comment Share on other sites More sharing options...
flanso Posted September 17, 2009 Share Posted September 17, 2009 I think the bank 1 and bank 2 A/F ratio sensors are the same except for the length of the connector wire, one being about 2 inches longer than the other. The Denso factory website listed the same sensor number for my 2001 ES300, 234-9021, for both bank 1 and bank 2. I plugged that Denso number into Amazon.com and their $126 price was the lowest I found. Quote Link to comment Share on other sites More sharing options...
lookingatx Posted September 18, 2009 Author Share Posted September 18, 2009 The VIN for my car is JT8BF28G4xxxxxxxx. It is Model MCV20L-BTPGKA made on 02/01. Thank you sir! Quote Link to comment Share on other sites More sharing options...
Lexlogic Posted September 18, 2009 Share Posted September 18, 2009 I think the bank 1 and bank 2 A/F ratio sensors are the same except for the length of the connector wire, one being about 2 inches longer than the other. The Denso factory website listed the same sensor number for my 2001 ES300, 234-9021, for both bank 1 and bank 2. I plugged that Denso number into Amazon.com and their $126 price was the lowest I found. Here is a website for Oxygen Sensor it is on sale. Quote Link to comment Share on other sites More sharing options...
kashi125 Posted September 18, 2009 Share Posted September 18, 2009 Part numbers for the sensors you need are: 89467-41030 89467-41040 OEM online will cost you $149 each. If you don't see this price, PM me. Denso replacement for these is: 234-9021 This can be had on Amazon for $126 with free shipping: Denso 234-9021 Same sensor will work for both bank 1 and bank 2. (The OEM sensors are the same, except the difference in the length of the wire. One is 10" and one is 13". The Denso sensor has a 13" wire so it works in both locations). I recently replaced both sensors on my car with Denso (Denso makes the OEM sensors) so if you have any questions let me know. Quote Link to comment Share on other sites More sharing options...
lookingatx Posted September 25, 2009 Author Share Posted September 25, 2009 I got the sensors in the mail today. Both of them actually have a 10'' wire (they are total 13" in length inclusing the sensor itself). I am hoping this will fit bank2 as well. I'll keep you posted. Quote Link to comment Share on other sites More sharing options...
kashi125 Posted October 2, 2009 Share Posted October 2, 2009 I am surprised to hear that they have a 10" wire. On Denso website the description for this part number says: "Denso "first time fit" planar air fuel sensor, original equipment direct plug in, no wire cutting. 13.78 in. wire length." Did it fit? And is your check engine light gone now? Quote Link to comment Share on other sites More sharing options...
danfall Posted October 16, 2009 Share Posted October 16, 2009 I am surprised to hear that they have a 10" wire. On Denso website the description for this part number says:"Denso "first time fit" planar air fuel sensor, original equipment direct plug in, no wire cutting. 13.78 in. wire length." Did it fit? And is your check engine light gone now? Ever here back from the OP? Wonder how he made out? I have the EXACT same problem with my 2001 es300. Would like to know which part number I need based on my VIN. Anyone know how to determine this? danfall4 Quote Link to comment Share on other sites More sharing options...
kashi125 Posted October 16, 2009 Share Posted October 16, 2009 Ever here back from the OP? Wonder how he made out? I have the EXACT same problem with my 2001 es300. Would like to know which part number I need based on my VIN. Anyone know how to determine this?danfall4 No, didn't hear back from the OP. What code(s) are you getting? Quote Link to comment Share on other sites More sharing options...
danfall Posted October 16, 2009 Share Posted October 16, 2009 Ever here back from the OP? Wonder how he made out? I have the EXACT same problem with my 2001 es300. Would like to know which part number I need based on my VIN. Anyone know how to determine this?danfall4 No, didn't hear back from the OP. What code(s) are you getting? I get the P1155 code only and I have the two lights on showing up on my dashboard as others have stated. I've read a lot of the posts up here on the topic and from what you've posted it appears I need to buy a specific sensor determined by my VIN number. I'm away from home at the moment but tomorrow i can furnish you with my VIN in determining what exact part number i need. I would be appreciative. Thanks, Danfall4 Quote Link to comment Share on other sites More sharing options...
danfall Posted October 16, 2009 Share Posted October 16, 2009 I have the same problem with my 2001 es300. Was wondering what your outcome was? Could you update us all? Danfall4 Quote Link to comment Share on other sites More sharing options...
kashi125 Posted October 18, 2009 Share Posted October 18, 2009 danfall--if you are only getting p1155, it is for your Bank 2 Sensor 1. This sensor is located right in front of the engine. When you open the hood, you should see it (between the radiator and the engine, on the exhaust manifold). Very easy to replace. Shouldn't take more than 10 minutes. The Denso catalog is showing the same part number for this (234-9021) as mentioned above. This can be had on Amazon for $126 with free shipping: Denso 234-9021 If Amazon is out, they sometimes have a third party selling it but you will have to pay shipping. Now the funny thing is that Amazon site says it does not fit a 2001 ES300, but Denso catalog says that it does. Same thing happened when I ordered the sensor for my 99 ES300. Amazon said it didn't fit, but I ordered it any way (based on Denso catalog) and it worked fine. Quote Link to comment Share on other sites More sharing options...
danfall Posted October 19, 2009 Share Posted October 19, 2009 Thanks for the information. I went ahead and ordered the part from Amazon. Hopefully it will show up in the next three days or so and I can install it. Will let you know how I make out. Thanks again Quote Link to comment Share on other sites More sharing options...
danfall Posted October 22, 2009 Share Posted October 22, 2009 The problem is fixed!! :D A BIG thanks to Mr. Kashi125, or should I say Dr. Kashi for all your valuable insight! Where do I send the Lobsters? To recap, my 2001 Lexus ES300 with 59K miles failed the 2009 Massachusetts Auto Inspection test. The code I got was P1155 only. ( Not P1155 AND P1135 which suggests a different sensor location I believe; the Dr. may care to comment). With the guidance of Dr. Kashi ( see his previous posts in this same thread) I purchased the DENSO 234-9021 sensor Monday morning on Amazon for $130 (including shipping) and to my surprise it was delivered Tuesday afternoon. The location of the sensor in the engine compartment is shown below: The old sensor is the one on the right in the following photo: Using a 22 MIL open end wrench I was able to loosen and remove the sensor from the manafold easily (your experience may differ ;) ). After that I simply unplugged the connector by pressing on the right side of the female connector housing (facing you in the photo below......ok this is getting to detailed ;) ). After that I installed the new one. I started the engine and initially both lights came on :cries: ( bummer!!). I let it run for about five minutes. I then shut the engine off, waited ten minutes and started it back up and the lights were off. :D Quote Link to comment Share on other sites More sharing options...
kashi125 Posted October 22, 2009 Share Posted October 22, 2009 danfall--that is awesome! I'm glad to hear that your problem is fixed. Thanks a ton for uploading the pictures and posting your success story. This is what adds value to this forum--people posting the results, so that future readers can know what works or doesn't work. lol @ "Dr." I'm no expert, in fact whatever I learned when I ran into this problem was from this forum. I was able to fix my problem for under $300 when it would have easily cost >$1000 at a dealer. P.S: Before changing the sensor, it is a good idea to disconnect the negative battery cable. Disconnecting the negative terminal for 10-15 mins erases the codes in the memory. Then when you put the new sensor in, the check engine light will be OFF when you start the car. During the next 5-10 mins of driving, the car will check the sensor voltages and put out a code again if there is still a problem. Quote Link to comment Share on other sites More sharing options...
danfall Posted October 22, 2009 Share Posted October 22, 2009 Kashi - Thanks for the additional information on how to reset the lights. I knew that after I put in the new sensor there had to be an additional step to reset the lights. Just didn't know what it was . Now the procedure is complete. Thanks. Quote Link to comment Share on other sites More sharing options...
jm4Lexus Posted November 6, 2010 Share Posted November 6, 2010 Hello All, I have a 2001 ES 300 with the same code, P1135. Since it's the same year as danfall's, can I use the same part number or do I need to post my VIN for help? Thanks, Jeff Quote Link to comment Share on other sites More sharing options...
jm4Lexus Posted November 17, 2010 Share Posted November 17, 2010 Bump. :) Quote Link to comment Share on other sites More sharing options...
Stinger1906 Posted November 22, 2010 Share Posted November 22, 2010 Thanks 'danfall' for the detailed information. I couldn't follow to the letter because it was a 2002. I did go with the original part from Toyota (89467-33050). There were two things I had to do differently because of the awkward position of the oxygen sensor. I had to purchase an Oxygen Sensor Crowfoot Wrench ($10.99)to get at the part on the right angle, 2) I had to remove the air intake to get to the tab to disconnect the wires (just 2 screws). After that everything snapped together perfectly and car seems to be working perfectly (NO ENGINE LIGHT). Had to reply just to let everyone know that this does work. Quote Link to comment Share on other sites More sharing options...
WHITE44BOY Posted January 12, 2016 Share Posted January 12, 2016 Hello , I'm having the same problem . I got codes p1135 and p1155 will both be the exact same sensors ? And is Bosch sensors good or denso? Quote Link to comment Share on other sites More sharing options...
