branshew Posted September 12, 2009 Share Posted September 12, 2009 I am experiencing what I think is a rubbing when I turn the wheel. When I make a turn in either direction passing through the 10:30 position at the top, I feel and hear a rubbing in the steering column. Is there anything in the steering column that can be lubricated. Quote Link to comment Share on other sites More sharing options...
camlex Posted September 13, 2009 Share Posted September 13, 2009 No, i have same issue, my mechanic told me to leave it alone since i have 362K miles. he did mentioned, you have to take steering wheel off and fix wiring/spiral etc. to much labor cost. Hope that helps. Quote Link to comment Share on other sites More sharing options...
branshew Posted September 14, 2009 Author Share Posted September 14, 2009 After a little investigation today, I discovered that the mechanism was rubbing on the rubber boot that shields the column as it penetrates the firewall. A little grease and problem solved. Quote Link to comment Share on other sites More sharing options...
