Transmission Fluid 1992 Ls400
felixthekat
But if you're doing a drain + fill (not a flush), it will be closer to 2-3 qts. By the way, I'm right down the freeway from you. Putnam Lexus charged me $7+/qt for the first 2 qts I needed after buying the car. Since then, I've learned I can get it for $4.50/qt by the case at the Toyota 101 dealer.
This is one of those things that it is best to stick with the factory spec: Toyota Type 4 ATF. Don't go with Dexron III or anything.
Good luck.
