wiseguy2706 Posted August 13, 2009 Share Posted August 13, 2009 does anyone know how to remove the serpentine belt on a 95 sc300? Quote Link to comment Share on other sites More sharing options...
2004m4 Posted August 13, 2009 Share Posted August 13, 2009 does anyone know how to remove the serpentine belt on a 95 sc300? very easy... take a socket wrench or a torque wrench-prefereably a torque wrench and place the socket over the bolt for the idler pulley and rotate clockwise.. the belt will loosen up and you can simply just remove it and replace the same way.. Quote Link to comment Share on other sites More sharing options...
john denninger Posted August 18, 2009 Share Posted August 18, 2009 does anyone know how to remove the serpentine belt on a 95 sc300? To replace the belt, first take a good look at the path of the belt. There should be a diagram on the under side of the hood or thereabouts to help you as well. When you are ready to proceed, take a wrench that fits on the bolt head on the tensioner on the upper driver's side just past the power steering and pull so that the belt becomes loose enough to take off the nearest pulley. Remove the old, install the new and, pulling on the tensioner again to allow putting the belt on the last pulley. Make sure the belt is all the way on all the pulleys before starting the engine. Quote Link to comment Share on other sites More sharing options...
