Have 2004 GX470 - finally the battery died... Had no choice but replacing the battery in the parking lot knowing there are many things won't work after the battery replacement.
I read the forum and was able to fix the window control from driver side.
But I haven't seen any post regarding to the problem with programing the driver seat. Currently I can't program it.
In addition, any other issues that I need to be aware of ?
Sounds like this should be part of the FAQ...
Thanks for any help.
Programming the memory seat? Place everything where you want it and then hold down the "set" button and then press and hold whichever number you would like it to be...(1 or 2)...until it beeps. Then you're done.
