davemc Posted July 15, 2009 Posted July 15, 2009 Hi all, I have a '95 SC400. When I turn on my AC, the compressor kicks on. It blasts cold air for a minute. Then the compressor shuts down, the air stops coming out cold, and the AC light starts to blink. From reading online I got the idea that is a bad sensor or relay. However, the compressor does kick on for a minute, so I'm not sure. Any advice would be greatly appreciated.
jzz30 Posted July 16, 2009 Posted July 16, 2009 there are several saftey features that shut down the ac system if certain things are not working properly. usually a pressure too low or two high can do this. you should go have the system checked out.
arielscar Posted July 22, 2009 Posted July 22, 2009 Most likely means your AC Compressor is shot; I had exactly the same thing happen at 108K and the blinking means a bad compressor. Look around for a good AC rebuild service for your unit rather than stick an exchange unit on. dg
