Kkirbs Posted June 20, 2009 Share Posted June 20, 2009 does anyone else have the problem that when the air is on...a constant vibration rocks the car incessantly. I think it's the A/C fan because when the air is turned off it stops but when the air is on the entire car vibrates and its really annoying...its a 2006 if that helps Quote Link to comment Share on other sites More sharing options...
eugene.s Posted June 21, 2009 Share Posted June 21, 2009 does anyone else have the problem that when the air is on...a constant vibration rocks the car incessantly. I think it's the A/C fan because when the air is turned off it stops but when the air is on the entire car vibrates and its really annoying...its a 2006 if that helps i always had the same discomfort with A/C turned on on all cars I had. just believe its normal. further to vibration, I also felt some "punch" when applying the brakes half-way, e.g. in a jam, when I stop and then slowly release the brake, there's a feeling as if someone got smashed into you from the behind -- you would have to apply the brake more firmly to stop the car. overall, not such a big prob, just need to be a bit more careful when you turn A/C on... Quote Link to comment Share on other sites More sharing options...
