2006 Sc430 Oil Change
fixit
I've just purchased a 2006 SC430. I've changed the oil on every vehicle I've ever owned myself. After getting under the SC430, I was wondering what lies on the other side of the "belly plate"? Does anyone out there have an 06' and change their own oil?? Are any special tools needed? Any special precautions?
Thanks In Advance,
Fixit
wow,, I bet there is an engine behind the plastic air foil... with a 10 mm wrench you can see for yourself... I always change my own oil, replaced my own timing belt, have just under 200k miles on my 2003 and not one mechanical problem. Even getting 50k on tires after my swing arm modification.....
So what mods were made to the swing arm, please tell. Asif uk
