pmurray633 Posted June 8, 2009 Share Posted June 8, 2009 I have a 2003 LS430 without navigation. I am a noob, but I searched, I get ERROR3 when I try to play a CD. If I try to eject a CD, it says that it is ejecting, nothing happens, then the screen goes bank, same thing when I try to LOAD a CD. Anything I can do to right this problem? I have no problem taking it all apart, but I thought I could get some guidance from the forums, thanks a lot! I found in the book that ERROR3 is an error with the CD and that it needs to be ejected, but I can't eject.. Quote Link to comment Share on other sites More sharing options...
bainzey Posted June 8, 2009 Share Posted June 8, 2009 I have a 2003 LS430 without navigation. I am a noob, but I searched, I get ERROR3 when I try to play a CD. If I try to eject a CD, it says that it is ejecting, nothing happens, then the screen goes bank, same thing when I try to LOAD a CD. Anything I can do to right this problem? I have no problem taking it all apart, but I thought I could get some guidance from the forums, thanks a lot!I found in the book that ERROR3 is an error with the CD and that it needs to be ejected, but I can't eject.. Do a search in the forums, and you will find a few threads on what it can be (Jammed cd, or laser issue)... In my case when I had Error 3, to get the CD out, I repeatedly hit the eject button while it was "trying" to eject and it did the trick to get the CD out. Quote Link to comment Share on other sites More sharing options...
