vuman1 Posted June 7, 2009 Share Posted June 7, 2009 I have a PO441 code reading from Autozone. The printout indicates it could be 1) Block Vapor Canister, 2) Vent Solenoid Malfunction, or 3) Purge solenoid Malfunction. How do I know which one it is and where should the location be? Thanks very much for your help. Quote Link to comment Share on other sites More sharing options...
blake918 Posted June 7, 2009 Share Posted June 7, 2009 Here's the PDF for P0441 and the trouble areas associated with that code... CI__P0441__P0446_.pdf COMP.pdf INSP.pdf Quote Link to comment Share on other sites More sharing options...
