synister619 Posted June 4, 2009 Posted June 4, 2009 I did a search, but couldn't find any results. Is there a way to get the DVD sound from the rear seat entertainment system to play through the vehicle's speakers, or must you use headphones only? Thanks.
BadBrad Posted June 17, 2009 Posted June 17, 2009 I did a search, but couldn't find any results. Is there a way to get the DVD sound from the rear seat entertainment system to play through the vehicle's speakers, or must you use headphones only? Thanks. Set audio mode to Aux.
rick - thousand oaks Posted July 23, 2009 Posted July 23, 2009 I did a search, but couldn't find any results. Is there a way to get the DVD sound from the rear seat entertainment system to play through the vehicle's speakers, or must you use headphones only? Thanks. Set audio mode to Aux. I couldn't figure out how to do it on mine either. This didn't work for me. Did you figure it out?
skyfish400h Posted July 23, 2009 Posted July 23, 2009 I did a search, but couldn't find any results. Is there a way to get the DVD sound from the rear seat entertainment system to play through the vehicle's speakers, or must you use headphones only? Thanks. Set audio mode to Aux. I couldn't figure out how to do it on mine either. This didn't work for me. Did you figure it out? Chances are very good that unless you have the factory RES (center mounted in the ceiling) you will need to use the headphones. It is possible to route an aftermarket DVD player (mounted inside the head rest, or elsewhere) to the AUX or CD2 inputs on the head unit, but it would likely require a 3rd party adapter such as the VAIS. http://www.vaistech.com/products/home.php Hope this helps.
rick - thousand oaks Posted July 23, 2009 Posted July 23, 2009 Thanks! I do have the factory installed version though. I have tried reading the manual but the manual does not refer to anything but headphones.
lemon Posted July 24, 2009 Posted July 24, 2009 Just press your 'disc' button twice. The first push will activate the 6 disc changer, the second push will output the sound from the rear entertainment system.
rick - thousand oaks Posted July 27, 2009 Posted July 27, 2009 Thanks! I got it to work! I don't know why it isnt just stated that way in the owner's manual. It drove me crazy not being able to figure it out B)
Judeclark Posted April 24, 2019 Posted April 24, 2019 Waoh! It's so amazing how you can get a bunch of problems solved when you have smart people around you who truly enjoy being helpful. Just fixed mine too. Thanks
