Midnight Ruby Posted May 29, 2009 Share Posted May 29, 2009 Suddenly I have sound problems. Even if the Audio is off, there is a thump, thump, thump (at a rate of 40 per minute) non-stop! This started 4 days ago. Since then, if the thump is absent, I can turn on audio and get radio or cd just fine. But, it will quit and the rhythmic thump starts again. I think its worse than silence! I have an appointment at the dealer tomorrow morning. Any ideas on this problem? I don't want a big bill and no solution and I think I'm crazed from the constant thumping. Quote Link to comment Share on other sites More sharing options...
Lexucan Posted May 30, 2009 Share Posted May 30, 2009 Is the thumping consistent in its timing per minute, or is it more sporadic? If it is sporadic, I would tend to think it might be a loose connection somewhere. If it is consistent, i.e. the same interval between thumps all the time, It sounds like perhaps you have a failed component inside your radio or amp. Quote Link to comment Share on other sites More sharing options...
