Hi guys, I have a 99 LX470 and brake pedal stays down when I release the pedal and I have to pull it up in order to release the brake, and it makes sound from rear when disengaging the pads. Any advise?
Thanks
Seems as if it could be a loose or damaged caliper mounting bracket on the rear maybe causing it to stick, or a damaged brake hose that has a deteriorated lining and doesn't let the brake fluid return to the master cylinder....or could just the the master cylinder itself that is malfunctioning. I'd let a dealer check it out before you have an accident.
  • 1 year later...
